Steering Column Questions
Shack
North Carolina
Mathew
So my original truck is a 1985 K10. No tilt, no cruise, wiper controls on the dash. I have a column from an '87 which has tilt, cruise and the wipers on the column. There's a couple things I'm not sure of but have an idea and looking for help.
This little black wire comes from the column. I believe it goes to the wiper/cruise control switch and I believe it's for the cruise control which I will not be using. Can anyone confirm?
Also, I found this wiper delay module. Seems simple. I'm using a brand new 27 circuit 73-87 Painless wire harness. Where can I find the connector that goes on the other side of this module and where does that connect to? I didn't see anything in my kit nor was I successful at my google search. Thanks in advance.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
That is positively from the cruise switch.
Shack
North Carolina
Mathew
Any suggestions on the other connector for the wiper delay module?
85 Shouldn't have had the wipers on the dash. 84 and later have the Multifunction Switch with the Wipers, Cruise if equipped, dimmer switch and wiper washer all on the turn signal switch. No dimmer switch on the floor and no wiper switch on the dash.
Shack
North Carolina
Mathew
My truck is an '85 and the wiper switch was on the dash and I had a floor dimmer switch. It had the harness for it as well. I just pulled the steering column off last week and it doesn't have a wiper switch on the column nor does it have the module. I haven't dug too deep into the factory harness to see if the connector I need is even there, but either way, if it isn't then I need to find it.
I'd be guessing to say your truck most likely had a cab swap then with an 83 or older cab. Where is your dimmer switch and does it work and where is it wired?
Shack
North Carolina
Mathew
It was on the floor and it did work when it was there. Either way, hoping to find this connector. Hoping it's on the original harness and I can swap that into the new one. Can't seem to find one online.
You are correct on these parts and the cruise wire.
So if it's really an 85 truck, then at least the harness, probably the whole cab has been swapped with an 83 or earlier.
Shack
North Carolina
Mathew
Assuming that's the case, where can I find the "truck" side connector for the wiper delay module?? I can't find them online. I haven't called painless yet but I will later today.
Also, the side of the connector that's not hooked up (the side I'm looking for), I presume that gets hooked up to the washer motor or tied into the fuse block?
Shack
North Carolina
Mathew
This is what was in mine but like I said, I'm trying to do away with it. I just can't find the female connector for the module.
yevgenievich
Place
Name
Year
Model
Size
I might have the connector, but would be up to a week before i can look for it. That connector is not delay wiper specific. Non delay wiper trucks should have the same connector on the underdash harness for the wipers.
Shack
North Carolina
Mathew
I looked and couldn't find it. The connector I have attached to my wiper switch will not fit the wiper delay module. It's not even close to being the correct one.
Shack
North Carolina
Mathew
My current wiper switch on the left and you can see its connection vice the module on the right and the plug needed for that.
yevgenievich
Place
Name
Year
Model
Size
It should be same as post 85 trucks with column mounted wiper switch but no delay module. Just a bit different way to search.
If you still have not found it in few days, I will try to look through old wiring harness.
jlyon1006
