Frankie
- Dec 15, 2017
- Three Rivers, Michigan
- Frank
- R3500
I have a '89 R3500 with the older style, not what is found in '89 1500 or 2500, steering column. Cruise and tilt. Question is this....tilt is about shot, can move the wheel up about 3-4 inches which makes it interesting to drive. Turn signal switch I believe is failing fast for the right as once you engage it you have to push down slightly to turn it on, then the wiper/cruise/turn lever has failed where wipers stay on all the time and end just spins. Ok, rebuild current column or attempt to find a donor with the same setup? I have looked in local yards and all I can find are the later 89 style that will not work. I have never repaired a column, one of the few things I haven't done.
