Skyfall
- Oct 5, 2020
- Franklin, VA
- Ryan
- r3500 Crew Cab 4WD
- 350ci
Hello all...
I read this thread about the steering boxes (https://www.gmsquarebody.com/threads/squarebody-steering-box-id-and-interchange.3991/) and I noticed how similar the 2wd and 4wd steering boxes are.
My question is:
If I purchase a dropped pitman arm from someone like ORD and place it at the correct angle, can I use it after I swap in a straight axle into my 1991 r3500 in a push/pull steering configuration? I want to install a GM sway bar which is why I'd opt for the bump-steer prone push/pull steering.
I've spent hours researching the Crew Cab 2wd to 4wd swap and can't seem to find an answer to this one.
Regards,
My question is:
Regards,
