Nemo
- Feb 10, 2023
- Utah
- Bill
- K30
I recently replaced all the seals in the steering box on my 1977 K30. I am not a professional mechanic, but I feel that I did my due diligence in researching the project before I started. After I installed it and bled the system (I may have screwed up by bleeding it with the engine running instead of having the engine off) the wheels started drifting to the right.
Every time I’d turn it back to the right, it would slowly turn to the right, full stop. I set it on the ground and the weight of the truck held the steering box from turning by itself.
I took it for a short test drive and noticed that as I turned left it was like there is no power assist, but turning right was effortless.
After I had made a couple of stops, the right front brake started locking up. Even with the most minimal of pressure on the pedal. Needless to say the test drive was over.
I’m having a hard time finding any troubleshooting for the issues I’m having and am hoping that I can get some help here.
Thank you
Thank you
