Steering arm removal
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Well after 4 days of torching, hammering, soaking in pb blaster I finally got them out. These things have to be the stupidest thing ever designed. I understand they make a tighter fit but come on really? This much trouble to take it off. VAL I messed the threads up beyond repair. I had to take a grinder to the stud to get the cone washer to slide out. Do I need to get a special stud or can I just get a grade 8 bolt and nut if I can't find the right pitch?
Sent from my XT901 using Tapatalk
nvrenuf
Mobile, Al.
Needs to be a stud. The clamping force is different from a bolt.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Any links to buy them from?
highdesertrange
kalifornia
mike
k30
call arp for a stud I bet they could fix you up. highdesertranger
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
I ordered a kit from a guy on eBay. Harshterrian I think his name is
bigcountryguy19
Sealy texas
josh
6.2 diesel
Just be careful removing it, try to get a stud removal tool if you can, if it breaks off it will be another pita.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Actually the one I had to grind we just welded the nut on it and it spun right out and the others just took a monkey wrench on it real tight and it spun right out
bigcountryguy19
Sealy texas
josh
6.2 diesel
That's good, glad to hear they came out ok
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Yea it was really surprising how easy they were with everything else giving me trouble
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Need help going to put the studs in and I have to put the nut on tighten them but they just back out.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
When I goto loosen the nut
highdesertrange
kalifornia
mike
k30
they are backing out because you are probably using the c-lock nut. they should just screw in by hand. if they don't, get two regular nuts screw one on and then the other. lock them together by holding the bottom one with a wrench and tighten the top one against it. then run the stud down using the top nut when it's down break the two nuts apart opposite the way you installed them they will not remove the stud once you have broken them apart. I hope I explained this so you can understand if I was there I could show you. highdesertranger
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
I got it already in the process of putting the oil in the diffs. I don't have a pump just a hose and the oil. Taking forever
das5439
