Starting problems, now zero power!
Dadjeans86
Suburban
Battery has worked just fine all year and it turns over nice and fast. 12.9 volts to it. Also it cut out abruptly when this occurred. I tried hitting the key a second time right after and I saw the buckle up light come on very dimly and fizzle out. Then nothing at all
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Just keep in mind voltage and amperes are two different animals. Your battery may be good, and even it's not it could show proper voltage when it's the cranking amps that it's lacking. You'll know once you tackle the other stuff. If it were me I'd still take it out and have it load tested since you're going to the parts store anyhow. But that's just me, I don't like making extra trips to the parts store if I can avoid it.
Dadjeans86
Suburban
Sorry to keep posting, but just checked battery voltage with key on and I'm only getting like 1.6 volts.. key off its at 12.9?
Maybe it is battery after all (Walmart special)?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Worth a check at the store. You may be coming home with a fresh battery
Dadjeans86
Suburban
I think you nailed it dingo.. I'll let you know
Dadjeans86
Suburban
Problem solved!! It WAS battery after all.. I just didn't expect it to be so abruptly toast. Wouldn't be surprised if that was the culprit of my intermittent click as well. Thanks for the help everyone!
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Glad it was solved so easily!
Dadjeans86
Suburban
Thanks for your suggestion.. I skip the simple things too often haha!
ali_c20
Austria
Alexander
C20, K5
Had a battery issue with my Audi... drove to a shop, everything as usual. Five minutes later when I wanted to start the engine: dead. Not even any lights at the dashboard. Seems to be a feature of the new batteries.
Chvywolf
