Starter Wiring Heat Shield - Where does it go?
militaryjeep
chatsworth
steve
Suburban K20
1986 K20 Suburban with 350
I bought this truck without a motor (full build thread coming soon)
I am ready to install the engine I put together but cant
figure out where this wiring heat shield tube mounts?
Looks like it protects the wiring from the factory Header type exhaust
manifold. This truck has the Federal "M" emissions with the stainless
exhaust manifolds and pipes.
Anybody have a similar installation they can send a photo of?
Does it bolt where the ground strap goes maybe, pointing down? I cant think where the bracket would bolt to
militaryjeep
chatsworth
steve
Suburban K20
The photo is a little misleading, the harness is draped over the AC unit when I was re-taping everything. I think the tube mounts
down next to the starter somewhere.
HOTFOOT
northwest ct
michael
gmc k3500 srw
It bolts to the second bolt up on the trans same place dip stick bolts to on an auto. mine is a 80 k3500
militaryjeep
chatsworth
steve
Suburban K20
Awesome!!!
Thanks for the photo, that helps me out
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
My truck does not have this starter wire heat protection tube.
does anyone know where I can get one?
i have one. just a bunch of old starter wires and stuff, i can look for a photo
If you have an automatic it bolts to the 2nd bolt from the bottom passenger side of the tranny and the other end bolts to the outer solinoid bolt. its the same for manual or auto
ive seen people use conduit and just use appropiate clamps, might be cheaper or easier
Curt
Loco Hills
Curt
K-30
You could just make one....or route the wires better than factory
BJedi76
Soldotna, Alaska
B.J.
305”
I got some spark plug wire heat shield sleeve material.
das5439
