- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Yep, you prolly had all short bolts. Cuz it's true, if you use to long of bolts, you can be bending or binding a pushrod too depending on which bolts it is. What else am I forgetting that bolts to long with screw up? Seems there is something else too along those lines.
This is going to drive me nuts. When I get home I'm yanking bolts out of everything, I got a couple virgin motors to check out too.
The fuel pump rod.
Remove short bolt, thread in a longer one to hold the rod in position while you mount the pump.
I bet some folks forgot to put the shorter bolt back in.
Yeah most people don't know about that bolt. The PO of my '84 dealt with an oil leak for years because that bolt was missing. I noticed it the first day I owned it, put a bolt in, then laughed at the PO (he's a friend).
