clkelley
- Mar 31, 2012
- Galax, Va
- Chris
- 2500HD
- 6.6L
1/2 ton 2wd have 5x5 and Caddy calipers with the e-brake, here in Texas you have to have an E-brake to pass inspection.
You already have calipers and discs in the back? The kits for the back from SSBC do not have the E-brake in the hub of the disc, but they have a mechanical E-brake built into the caliper, but it is not the ratcheting type, it is apparently some kind of screw type design exclusively from SSBC. They also have the Firm Feel master cylinder to help with overall pedal feel and improved brake pressure closer to a hydroboost type of set up.
