clkelley
- Mar 31, 2012
- Galax, Va
- Chris
- 2500HD
- 6.6L
Ok, here is the deal guys and gals. I DO have access to SSBC read drum to disc brake conversion kits. Not only do I have access, I am a Manufacturer Wholesale Direct Account holder with them.
That being said, here is what I am looking for. I need input from the members on what you would like to see the most. Would you like to see a group buy on the rear drum to disc brake conversion kits or something more along the lines of a good forum member discount for anything from SSBC?
Vote in the Poll and let your opinions and suggestions be known in this thread. This will go a long way to helping the members here get the parts they need at the absolute best and dare I say unbeatable pricing as I have already spoken with my contact at SSBC about some major promotional stuff. But to make sure I set things up in such a way that best benefits the majority of the members here, I need your input.
Thank you for your input in advance and I look forward to hearing what you have to say.
Also, I posted the poll to last for ten days, but I will be making a decision to post a promotion ASAP so make your voices heard as soon as possible!
Product Features
Sport R1 Rear drum to disc brake conversion kit with 11.5 in. rotor.
All hardware included.
Caliper includes built-in parking brake.
Rotors standard with Turbo slotting and Xtra Life plating.
Vehicle Applications
1974-1991 Chevrolet Blazer K10
1973-1987 Chevrolet K10 Pickup
1974-1991 Chevrolet Suburban K10
1973-1991 GMC Jimmy (Fullsize 4WD)
1974-1991 GMC Jimmy K10
1973-1987 GMC K10 Pickup
1974-1991 GMC Suburban K10
Caliper Specs
Name
Sport R1
Number of Pistons
Piston Size
54mm
Constructed From
Aluminum
Standard Finish
Clear Anodize
Optional Finishes
Powder Coat
Rotor Specs
Diameter
11.61
Thickness
1.000 in.
Venting
Uni-Directional
Standard Finish
Standard
Optional Finish
Slotted & Plated
Bolt Pattern
6x5.5 in.
Important Information
Minimum wheel size: 15
Product Features
Caliper Specs
Name
Sport R1
Number of Pistons
Piston Size
54mm
Constructed From
Aluminum
Standard Finish
Clear Anodize
Optional Finishes
Powder Coat
Rotor Specs
Diameter
11.61
Thickness
1.000 in.
Venting
Uni-Directional
Standard Finish
Standard
Optional Finish
Slotted & Plated
Bolt Pattern
6x5.5 in.
