Spring Bushings Moving
GregL
Palm Springs, CA.
Greg
K 20
When I bought my truck a couple years ago the front spring bushings looked a little beat up/worn so I replaced them. They were a tight fit as expected. A couple of weeks later I noticed both front bushing have walked out to the left. I pounded them back in, couple weeks later same thing. Rear bushings have not moved. Truck is straight, no hits, no heavy off-roading. Drives straight down the highway, no tire wear or pull/drift.
Your thoughts?
Greg
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Your thoughts?
Greg
Are the springs OEM? Where did the bushings come from? How did you get the old ones out?
GregL
Palm Springs, CA.
Greg
K 20
It has newer aftermarket springs. The orig. owner replaced them not long before I bought the truck. Pressed out the old bushings, pressed in the new ones. They were tight.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Almost seams like the spring eye has opened as if the heat treating process was substandard.
GregL
Palm Springs, CA.
Greg
K 20
I just don't know HK, bushings seem to be a pretty tight fit. Both sides on the front are doing the same thing but the rear bushings on the front springs are staying in place.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The front eyes don't have the movement the rears eyes do and don't take as much force. If the front eyes weren't tempered properly they will be the first to open up because they take more of a pounding. I'm not a metallurgist and I don't play one on tv but the eyes would of had to open up if that bushing is sliding out.
74 Shortbed
WOW, I've never seen that before...
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
The only way I see that the bushing could move out on its own is if there is now less friction between the bushing and spring than when it was originally installed. Perhaps the bushings you replaced were a touch undersized (talking mere thousandths) or like others have said, the spring eye has opened up enough to allow the movement as well.
yevgenievich
Place
Name
Year
Model
Size
My stock bushing on a stock spring walked similar. Aftermarket poly bushings should have a shoulder on both sides. I had to pull spring back to install with a new set.
Edit: yours is a bit different, it moved on a metal sleeve part instead of rubber. The aftermarket springs are probably a bit off and might work with a poly bishings that have a shoulder
GregL
Palm Springs, CA.
Greg
K 20
Yev, that's exactly what I'm talking about. Same issue. Did you switch up to the poly bushings and did it solve the problem? If the poly bushings have a shoulder does that mean they have no steel sleeve?
Greg
Craig 85
Nashville, TN
454/TH-400/NP205
I had Tuff Country springs in my '79. I switched to ORD bushings as they were greaseable. They have the metal sleeve. I don't recall if the orginal Tuff Country's did, but I believe most poly bushings do.
http://offroaddesign.com/catalog/hdshackles.htm
yevgenievich
Place
Name
Year
Model
Size
I am using greasable offroad design poly bushings. There is a metal sleeve inside.
Greg
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
My Energy Suspension ones have a sleeve too and I don't think there is room for any slide out movement.
highdesertrange
kalifornia
mike
k30
aftermarket springs have poly bushings with shoulders and a steel inner sleeve no outer sleeve. it appears you have installed factory bushings on aftermarket springs, not correct. highdesertranger
GregL
Palm Springs, CA.
Greg
K 20
HDR, this is the same style bushing that was in the spring when I got the truck. I suppose they could have been tbe wrong bushings as well.
I will try to locate the shouldered poly bushings.
Thanks
78silverado
