Speedo with trip odometer?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I don’t normally drive my truck in the winter, but I needed to today. While the engine started instantly in the 8 degree weather, the rest of the truck wasn’t happy!
Problem #1: the blower motor screams when it’s cold. Fortunately, that didn’t last long.
Problem number 2: the speedometer HOWLS when it’s cold. It has always bounced around a little (even after cleaning and lubing the cable) but I have never seen a speedometer react to the cold like this! Before I even made it out of my neighborhood, the speedometer had wrapped itself around past the 85mph, sll the way around to the 35mph point. As the truck/speedo warmed up, it eventually settled down again.
My question: was a speedo with trip odometer ever offered in these trucks? I seem to recall reading where someone adapted a speedo from a similar year van.
Just curious.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Just curious.
My squarebody Suburban has a trip odometer in the speedo, but the knob/shaft that you use to reset it is frozen so I can't re-zero it. My speedo reads about 5 higher than actual, and a bit more than that when cold.
mcarlo86
ND
Suburban
I could be wrong, but I believe the trip meter speedometers were the electronic ones in 89-91 Blazers and Suburbans. Our '90 also has the trip, but it doesn't reset either.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
88-89 also had trip odometers. Both my 88 crew cabs have them, but my 87 R10 doesn’t so I believe the start was 1988
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I didn't think it was electronic, but I could be wrong. Not going to try to get under the dash to look until things get drier and warmer.
chungo
