Spark plug wires
84GMCSierra
Central Arizona
C2500
What can you all recommend for a factory fit set of wires for a 350? The set I got from Autozone are definitely universal. Some are very long and some are short. I need something that fit the way they are supposed to. I would prefer pre made but if need be, a set I can cut and put boots and ends on would be a second choice. My truck is an 84 Sierra with an aftermarket 350. Thanks everyone
350 w/203
You're pretty much on the hook for making your own. It'll look real purdy. That's my 2 cents.
You can dress 'generic' wires back to the distributor. That will give it a more factory look.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The Taylor wire kits are pretty close if you order a kit for the proper year manifolds. But custom made is for sure the way to go.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Plus 1 on the Taylor's. I still have the top cover on my HEI and the Taylor's have the molded "nipple" on the top to plug into that. Most aftermarket ones do not.
84GMCSierra
Central Arizona
C2500
I have a new distributor, and the it doesn't have the cover ring. My old one didn't either
sidschev
Arkansas
sidney
c1500
i bought two sets from rockauto and used some from both sets for custom wire job on my 84
84GMCSierra
Central Arizona
C2500
I usually just get AC Delco wires
Do you get a pretty good fit with them? I looked those up just now, and even after entering my vehicle info all the sites show are for 1999 and up. Do you have a part number? Thanks
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I went ahead and spent the money on a set of msd wires for my 454. They fit really well and look good.
Had a set of Taylor wires on before these. Not a bad set but I like these better. Jmo
gmbellew
Kansas city
glen
suburban 1500
last set I got was from Oreilly's according to my email. they fit ok, definitely not custom. i just replace the wires one at a time and use the closest length new one. My OEM wire holders are long gone, so I just ziptie them up out of the way of things.
ACDelco Spark Plug Wire Set | ACD 9618V
that's what I used on my 1990 v1500 suburban. 350TBI.
Do you know how 84 ignition. Wires were routed? You should have some very long ones because the route down the back of the block around the sides of the block and come up to the spark plugs from below,with 90 degree boots,you really don't even see much of the wire. If you're wanting to go over the manifolds and down with straight boots,look up wires for a 76 1 ton 454.
84GMCSierra
Central Arizona
C2500
I have a drawing of the routing out of my 84 shop manual. I'll look at it and see how they were routed. I don't have any holders either, and want the cleanest look I can get.
sidschev
Arkansas
sidney
c1500
82sbshortbed----- how do you have the choke wired and also how do you have this (circled in red) trans thingy wired Please. i need to wire up a choke and also need to get the trans switch square thingy....​
Is the choke just wired to a hot ignition on
Poodlehead
College Station, TX
Pat
I have a stock 77 350. I'd like to route a new custom 'cut to length' set of wires like this, but I want the nipple for the dist retainer ring and 90 degree plug ends.
I'm having a hard time finding that combination. I found one set like this, but they are 10mm wires and I can't find a crimper that does 10mm wires. Any suggestions?
Thank you!
Do you know how the were routed factory. Just checking,a lot of people dont,and assume the wire are too long because they don't realize they are supposed to go down the back of the block,under the exhaust manifolds, and up to the plugs. If you are trying to go from the distributor over the valve covers and down to the plugs look at a set of wires for a 1976 1/2 ton with a 454 Napa #700242
Cantrell299
