Source for Tachometer Repair
Green79Scottsdale
G.R. - MI
Bob
Got a factory tach that does not work properly? Scared off by the $100+ pricetag usually associated with the repair. Well... I found an alternative!
I was browsing the classified forums at thirdgen.org, and ran across a guy that fixes tachometers, for $45! Being the ad was on a Camaro forum, I sent him a message asking if he had done tachs for our squarebodies. I sent him some pictures of my tach, and he said he thought he could. So I sent it to him to give him a chance.
Full confession... I have not actually hooked it up and tested it! My truck is not at home right, and with the temps in the teens/20's right now, I am going to wait for at least a slight warm-up. He has all the equipment set-up to bench test them, so I don't see why it won't work.
His name is Greg, at he is located in Louisiana. I mailed my tach to him on a Monday, and he received it on Thursday. He had it done by Thursday of the next week, and sent it out on the following Monday (his delay in sending it was my fault, not his, payment issues on my end.) It was back in my possession on Wednesday.
He had to replace quite a few parts, as you will see in the pictures. The first two are before, the last two after. I do not know what everything is, but you can see what was replaced by comparing the pics. Really good, clean solder connections. I am looking forward to testing it!
Contact Greg Johnson at [email protected]
He prefers emails so that is all I am giving out. So far I am pleased with the work, and yes it was only $45! Hope this helps some of you that have a factory tach that you would like repaired.
I will update this thread next weekend when I get it hooked up and tested.
Do you know what model year your tach is from? I guess they changed through the years and some are not able to be repaired?
yevgenievich
Place
Name
Year
Model
Size
As long as components on the board are available it should be rebuildable
Green79Scottsdale
G.R. - MI
Bob
Green79Scottsdale
G.R. - MI
Bob
And if you know how to test things and can do the soldering, you can probably do this repair yourself for pretty cheap. I have neither abilities, so I will gladly pay the $45!
nasstyz28
WI
Aaron
c25
Have you tried the tach out yet? I'm curious to hear if the repair job worked
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
I called Greg to have my tachometer repaired (nice guy!) I was all ready to mail it to him and then I sent him pictures of the tach. This turned out to be a good thing because he discovered that my 76 / 77 tachometer has the ceramic board and he was not able to fix that type. He was nice enough to redirect me to Willcox Corvette in Indiana and I mailed it to them. 2 days later they contacted me and said that it was fixed and they are mailing it back. Those are very nice guys. I dealt with Tommy and Ernie, and I will let everyone know how well it works.
Green79Scottsdale
G.R. - MI
Bob
I am happy to report the tach works perfect! It is now installed in the truck and operational.
FRANKENTRUCK
By The Sea
Pierce
I finally got to test my newly fixed tachometer at the paint shop yesterday (where the truck is presently being painted). It works better than it ever has. I strongly recommend Willcox Corvette in Indiana to anyone who wants a tach fixed that has a ceramic back to it.
jmcbil24
