77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
Is this thread over?
Total cost?
Recommended? Would you do it again and if so, what would you do different?
How could one improve upon your efforts?
Whew! That's a lot of questions but I feel like you kind of left us hanging...
Everything on the brakes is working great. I've used them in deep snow, on freezing rain, pavement, gravel, mud. They work great- better than my old drum setup.
If I was to do it again:
Don't buy the fixed proportional valve that was supposed to be for front and rear disc brakes. That thing was worthless. That was $67 absolutely wasted and made me have to replace it with an adjustable one and then re-bleed the brakes.
The larger master cylinder. Not really liking that. Sure- it has more capacity. The lid is not very tight on it. It is so big it contacts the vacuum connection on the brake booster behind it. Also the brake lines didn't fit on the larger one. The ports were reversed. I went with adapters instead of cranking the lines around to swap them. I think I would have been happy with my stock master cylinder. This was $74 I don't think I needed to spend.
I didn't like the DIY disk brake brackets. I had one that was so twisted I couldn't run a bolt thru it to hang the disc brake calipers. Anytime you are putting bends on a bracket then welding on it, things are going to warp and twist. This caused me problems. I'd buy the ones thru Off Road Design. It is a big washer you stack next to a flat bracket. Nice and easy. More expensive... but the cheaper ones cost me more labor, and waiting another week and a half to get one that wasn't screwed up.
So if I did it again, this is what I'd get:
ORD disc brake brackets. $150
ORD braided stainless lines to each caliper. $89
Raybestos RC4072 Professional Grade Remanufactured, Loaded Disc Brake Caliper $57.48 (Amazon)
Raybestos 5014R Professional Grade Disc Brake Rotor $40.06 (Amazon)
Baer adjustable brake proportional valve. $50 (Amazon)
$386.54 grand total. (well, you need to buy brake fluid)
