77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I have been thinking about doing this for about a year. Recently had the brakes heat up pretty bad going down a very steep trail, so pulled the trigger and just ordered the DIY4X rear disc brake brackets and then new brake lines from ORD.
Now I still don't understand what I need to do with the brake proportion valve. Some say it might be ok. Some say no, need an adjustable one. Some say change the master cylinder instead to one that was made for disc/disc brakes. Some then say you need a master cylinder for disc/disc but it has to be a LARGE bore because you need extra fluid volume. If a newer style master cylinder is used, then my stock proportion valve can stay installed?
I feel stupid for asking this- but after hours of searching it seems like every truck is different, so everyone has their own way of "fixing" it. I don't see why every truck would be different.
