solid axle s10
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i was building this a few years ago i ran out of room and had to make some room so it got scrapped.
i messured a stock s10 and this one it had 17'' of lift over the stock one. i had the solid axle swap almost done only needed to rework the shackle hanger and do a cross over steering.
it used a jeep cheroke front axle swapped to 3/4 ton and a 14 bolt from a cab and chassis truck they were pretty close in width. i used 6'' front springs from a square body.
i had a blown up 350 and turbo 350/205 mocked up in in.
and i think those were 35'' tsl tires but i can't find the pics with them on it look awsome.
this picture is the only one i can find of it it was taken when i started the 3/4 ton swp on the front. i used the axle sitting in front of it for parts.
Cool. That is all attached to the factory frame? :popcorn:
Posted from mobile...
So I guess you just used the complete Chevy outers on the Jeep axle then? Did you have to use the Chevy stub shafts too? I work with a guy that's got a ZR2 S10, i keep telling him we should throw some Wagoneer axles under it... he ain't going for it.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I had a HP44 and a 9 inch awhile back or a solid axle Dome swap that were from an early Bronco it would have been a sweet setup but ended up selling them for some bill payin money.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Wagoneer (Dana 44) YES! Cherokee (Dana 30) NOOOO.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya it was the factory frame
it was a full size cherokee dana 44 and i don't remember but i think all i swapped was the brake backing plate,spindal,rotor and lock out hub
ssxa
