Smog delete question
bootlegger
southern Ohio
k3500
I need advice here. My 86 1 ton 454 somehow still has every piece of the original smog equipment! I think it is California emissions because there are 2 smog pumps. (?)
Anyway my question would be , on the exhaust manifolds, can I remove the plumbing from each side and just use pipe plugs to block them off?
Also, there are so many vacuum lines going to the carb that I wonder if I should just buy a new one?
Thanks
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Thanks
You can remove the pumps and plug the ports, but you will not see any benifits power wise, unless they are siezed up. Weight removal, about 10-15 lbs in this case is always good.
As far as vac lines, there may be one going to each bypass valve.
Do you still have the emissions sticker?
Q- jet is the best carb, just plug any lines you remove.
bootlegger
southern Ohio
k3500
I believe there is a diagram sticker on the air filter housing. I'd probably be way confused by that. I'm also worried about the vacuum advance.
There is a small manifold that comes off of the thermostat housing with 3 more vacuum lines attached.!!??
I agree with the q-jet reliability but there are so many ports on that carb I'm afraid it would look like a Rastafarian by the time I plugged them all.
I removed both pumps on my old '86, I just left the lines in the manifolds and pinched the outlet closed. I didn't remove the pumps and related stuff to gain power, the biggest benefit was room under the hood. It did require a shorter Alt belt though. I can get the part # if needed, or I think I posted it in a thread around here somewhere too.
bootlegger
southern Ohio
k3500
Well I'll need to figure out how to drive the alternator.There was one wide serpentine style belt that drove the lower smog pump and alternator from the crank.Now that smog pump is gone so I'm not sure how to drive the alternator yet.
That's what the shorter belt is for.
bootlegger
southern Ohio
k3500
OK.just seems funny to run a serpentine belt to one accessory.
That's how it was done on the small blocks of the 80's too. It's really not a serpentine belt either, since it doesn't drive anything on it's backside, not sure why GM did it that way. I'm not at home, so I can't go get the part# right now.
hydroman
