Small block be big block engine pedestal
HenleyTX
Conroe, TX
Brett
I have a 1985 GMC I’m installing a 454. Does a big block use the same frame pedestal as a small block? The part that goes from the crossmember to the frame.
85K304SPD
Las Cruces, NM
Richard
The big block will bolt right into the small blocks place. Buy the small block motor mounts for the truck, not the ones for the big block motor.
Show us what you are working on.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The above is correct. Yes, but no. Things will bolt up, but it won't be what GM intended. I had the same issue with the diesel swap. Bigger motor mounts and different perches.
Russo
