Small block 400
Joe383
Moses Lake
Joseph
Your transmissions TV cable is probably not hooked up correctly causing the shifting problems. You need the correct cable bracket and TV bracket for the throttle lever on the carburetor. I would recommend doing some mods to the transmission cuz it will not last long behind even a mild 400 if your hard on it. While the motor is out I would install a shift kit and if the kit you get dose not include a new stiffer regulator spring and boost valves for the oil pump and a corvette servo I would add these to the mods. I just installed a modified 350 in my Camaro with a stock 700R4 and it slips the transmission at high RPM 5,000RPM+ Not a great transmission stock un less it is behind a stock motor.
ExtraZ
