Sm465 to 4l60E swap
Go with what you can get cheap. It's said the NP241 is a hair better. Not sure if that's just the hair deeper L ratio or if it does indeed have a bigger bearing, but it's minimal so if you can score an NP208 for cheap, I'd go for it.
The 208's I've had have all treated me well.
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Thank you all once again for all the answers, now if one of you all could just tell me the secret to making millions of dollars without working that would be great.
highdesertrange
kalifornia
mike
k30
let me get this straight, you are trading out an SM465 and NP205 for a 4L60 and a 2xx transfers case. I guess we all have our own way of doing things. highdesertranger
roundhouse
atlanta ga
justin
77,78,79,80 ?
I swapped a 350 & 465 and 205 for a LS 5.3 NV3500 and 208
For a daily driver the 465 sucks
roundhouse
atlanta ga
justin
77,78,79,80 ?
I have a NV-3550 in my 74 bronco
It’s a great trans for daily driver in stop and go trafffic
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Agreed, the 465 to me is hard to live with on a daily basis. I don't tow, no need for the super low granny gear. I drive highway most of the time, and plan on taking my truck on power tour next year though work.
Catbox
Peter
C20 Silverado Camper Special
I just ran my truck along the highway the other day for the first time with its 465.
I found out that 4th gear is my 25mph to 85mph gear.
I just would like an overdrive for freeway driving.
Other than that, it will keep my son from getting to far outta line when he drives the truck.
Kyle Childress
Brownsville KY
Kyle
K20 silverado
85mph..... at 65 I'm turning 3200rpm+, but I have 4.56 gears also.
hoagster
California
K10, 1500
5.3l
Thanks for the thread, sticking with my 465/205
Catbox
Peter
Yup.
Sounds like the gearing in my VW, 3500 rpm for 65-70....
But my truck has the 3:73's in the rear.
So it is not so bad, not good, but still not bad.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Taller tires is the cheap way to fix that
33’s will fit in the back
brentjo
