Designo614
- Apr 3, 2022
- New Bern NC
- David
- Chassis Cab Tow Truck
So, my new to me 1988 1 ton with a Holmes wrecker body on her, and shifting issues continue. Here's what it's doing, and here's what I've done so far:
At rest, you can put it in any gear, however once moving, when it's time to upshift the stick doesn't move, like it's locked in place. Not grinding, just won't move. Once at rest again, it'll go anywhere. It also whined a lot so I determined my first course of action should be to change out the gear oil. Did that with a gallon of Sta-Lube 85-90 GL-4 Gear Oil. Turns out, I presume because I have a PTO attached on one side, that a gallon isn't enough, took about another quart, but now it's full to the bottom of the side fill hole. Removed shifter in order to fill from top, then learned the lesson on how to align the forks to reinsert. Test drive, same results.
So I inspected the clutch master and slave assemblies; turns out the pushrod going into the master had broken and the sharp edge had gouged up the backside pretty badly; and the flex portion of the line between master and slave was badly cracked at the hairpin turn. No leaks detected, but decided based on condition I would fully replace the whole assembly; did that, got it bled, and it seems that I am getting the pedal pressure and the travel needed to work properly. Slave cylinder travel is about 1", does that sound about right? Anyway, test drive, same result.
So, now I'm thinking that despite the new master & slave cylinders, perhaps the shifter is refusing to shift because the clutch is still not fully disengaging somehow, so I'm thinking I need to inspect it.
So, youtube suggests the way to replace a clutch on these is to remove shifter handle up top, remove driveshaft, support the tranny with a jack, remove the crossmember then remove bolts and slide the tranny back on the jack. Can this be done safely by myself, or do I need someone else there at least to call the medics when I drop it on my chest? Can someone point me to a good video or write-up about that?
One other thing, I understand that these can be hard to shift when the PTO is engaged; my PTO drives a hydraulic pump to feed the wrecker boom and wheel lift, and it has a plunger type-cable driven button on the floor to engage and disengage, however my wrecker hydraulics work no matter which position it's in. Could this be the source of the problem, rather than the clutch?
And, what else am I missing here? Sorry for the long post-
