- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Got two bellhousings, one is just a standard mechanical clutch type, the other is the hydro type and mounts the slave on the passenger side. The hydro bell has cracks at three of the four threaded bolt holes, I took a pic of the worst one. Should be repairable by anyone that can weld aluminum, it's a very hard to find part (only used for 3 years I think in the early GMT 400) otherwise I would just consider it as scrap. 50 bucks each and I have the fork for each also.
