Show your daily driver
Turbo4whl
Downingtown, PA
Wayne
There's no need to use brute force to remove that pin with the broken bolt. I ran into the same issue when trying to replace axle tube seals a few years ago, and my buddy brought over a kit like shown in the link below.
It worked well and he got the busted bolt out relatively easily. It's a pretty ingenious design. The best part is that there was no collateral damage to the carrier or anything else.
That's a game changer in my mind, at least a little bit. One of my concerns in changing the gears myself was the possibility of damaging the carrier banging the pin out. If I decide to do the gears myself I'll order one of those extractors. I've put one in my cart so I don't forget it. Would you mind elaborating on how it is used? I'm guessing the drilling part is done by hand? Did it take very long? Thanks.
Most GM rears, you can remove the right side bearing cap and have access to use a drill. Remember bolts are case hardened so the center is softer and drill-able. Use a 1/8" bit and use the Ridgid type screw extractor.
Calvin, that is a very interesting tool you posted! I might have to check that out.
You should take it for a run on the drag Racer app in Google play store. It's a really fun app.
Yours still works? After a while, my app couldn't keep a GPS signal for more than a second or two, which made it constantly reset. Maybe I'll download it again and see.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That sucks. I haven't tried it in a while. That was an old picture of the camaro. Now I'll have to try mine tomorrow now I have the new 700r4 in the square.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Update maybe?
idahovette
Weiser Idaho
Perry
K20-K10
My daily and my Bride's daily. 2017 Colorado and 2015 Tahoe. Colorado just back from G-daughter softball games. My Bride used to be the CO. Assessor, hence the plates
animal
Lee
c10 silverado
350ish
Got the windows tinted and cleaned up a bit
bluex
Spartanburg SC
C15
My daily the last two weeks. Except for the 10 mpg it's done pretty well. I went back to the charger today though lol it's getting warm an I still got to get the rest of the ac components replaced in the dually.
mxer147
Colorado
Jack
k20
Yea, I have been seeing a white Toronado on my drive home, sweet boat ride floating down the road. Talked to the owner at a stop light, said it has the BB 455 in it.
mxer147
Colorado
Jack
k20
I drive this one the most, 99 Bonneville, left work on Wednesday, and heard a crunchy sound, then the power steering was intermittent, temp started climbing and noticed some smoke at the stop light. Pulled into a parking lot and coolant leaking, water pump seized. Called tow truck, hauled it home, backing it off the flatbed and the rear lower ball joint decides to let go. I have some more work to do. Hopefully this isn’t a sign of more to come. I have another 235k to go before I retire it at 500k.
Big Ray
North Carolina
Ray
Admittedly I am a tad aghast at the lack of squarebody trucks found in this thread.
Cool idea OP dude. :waytogo:
On my way to work in a 1988 Blazer. 350/350/3.42s on 31-10.50 R15s.
(One way) I drive about 6500 miles a year. - it hauls ass and I drive fast. :headbang: Tell em Cube!
I use that same speedo app...
Cantrell299
