Should the windshield wipers park on a 1974?
Chris64
San Diego
I finally got around to adding wiper blades so I could try out the wipers. They seem to work but the speed didn't really change much from slow to fast. Also when I turn them off they just stop wherever I turned them off.
Are they supposed to park? Is there an intermittent?
I'm afraid to even test the fluid squirter :hahano:
They park, and intermittent was not an option until later years.
350 w/203
Check this out:
RiverRat4
north coast ohio
r0d
ls3
experiencing a similar problem in my 81 k10. replaced the motor/washer assembly because the original would not "park" the wipers but rather stop them wherever they are when the wipers are switched off. Same problem with the new motor assembly. Is there an external module or contact switch?
ali_c20
Austria
Alexander
C20, K5
It should park. The park switch is in the motor. Your wiper switch could be bad or wiring to the park switch or ground.
The thread linked below contains 2 diagrams:
https://www.gmsquarebody.com/threads/wiper-issues.18382/
You can test all functions of the motor with removing the harness and connect 12v and check with the grounds with jumper wires.
350 w/203
Be certain your switch is grounding.
mgoldbach
