Should i put an clutch fan on?
chengny
Well ive run into an issue. The fan i have is built for short bolts and nuts, my straight blade fan is put on with long bolts only.
any ideas on how to convert this setup?
Not really sure what you mean but here is a little known fact:
On an OEM water pump, the holes in the driven flange of the coupling are tapped for 5/16"- 24 NF. The first time the fan hub comes off the water pump flange, I re-install it using four bolts screwed in from the front. I believe the correct size is 5/16" - 24 X 1".
Any shorter and there may not be enough thread engagement (especially if using lock washers) and if they are any longer, the bolts are unable to be tilted into the space between the back of the clutch and the hub for assembly.
See these images - I am not explaining this well and they might help:
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i generally think you should switch, but you have to make the the shroud is right for it---that it actually fits in the shroud diameter-wise, but also that it is positioned properly in the shroud----not too far in and not too far out--should be half in/half out.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i have an unrelated question:
Does the fan have anything to do with A/C operation?
MikeB
North Texas
Before A/C became standard on just about every new vehicle known to mankind, larger radiators, HD fan clutches, and fans with more pitch were used to remove heat from coolant in the radiator AND refrigerant in the condenser.
If you're not pulling enough air through the condenser at idle, the A/C system won't blow as cold.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
So is there anything connected to the fan clutch that would make it engage if you turn the A/C on? Or does it not need it?
MikeB
North Texas
Not unless there are some viscous fan clutch setups that are somehow electrically controlled.
On a typical fan clutch, the amount of clutch engagement is controlled by temperature of the air drawn through the radiator and condenser. When the A/C compressor engages, that air will get hotter, which will further engage the clutch once the bi-metal spring responds.
firebane
Calgary, AB
Curtis
They exist ... but generally only found on MUCH newer vehicles.
Doug Hampton
