olnick
- Feb 7, 2019
- Milford NH
- Nick
- c15
- 1982 350 4 bolt mains
I just spent two weeks cutting/grinding /welding/painting on both of my NLA bed sides! Does anyone have a method to treat the inside of the bed panels? and the floor supports? the floor supports can only be accessed 1/3 of the way from each end! How do you treat the center portion? and the other smaller supports? The bed panels are too narrow to get any portion of my arm up in far enough to do any good. The front edge on the psg side took the biggest hit and the arch over the tire on the driver side. both tailgate posts were GONE from the floor down and an inch up!! Now that all is well again I'd like to "treat" as best I can to prevent this from happening again too soon. Has anyone tried drilling access holes inside near the top of the side rails to allow spraying oil Etc. the 3/8 inch ziebart plugs would fit in perfect to block off the holes these would allow access in between the panels? Any and all suggestions will be considered!!
Thanks
Olnick
Thanks
Olnick
