Shock mounts
87silveradok20
Ohio
Levi
Silverado k20
I'm gonna put a Dana 60 and a 14bt ff in and when they were taken off the shock mounts were torched off both. So my question is where should I get these at.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
They should be fine. Get it all mocked up so you can figure out the shock angles.
The shock mounts were most likely removed because the truck they were going into had a different mounting point for the shocks.
I can take a quick picture of the shock mounts for the 3/4t 14bff that i've got sitting around if you'd like to see.
87silveradok20
Ohio
Levi
Silverado k20
The shock mounts were removed because the idiot that took the axles off was having too much fun with the torch. And sure that pic would be helpful. I have a 14b sf to look at so idk if it's any different than that.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Alright. I'll grab a picture and a quick measurement in the morning if it still isn't raining.
87silveradok20
Ohio
Levi
Silverado k20
does anyone know about the front.
highdesertrange
kalifornia
mike
k30
make your own. use square tubing, use a hole saw close to the diameter of your axle tube. the rear is easy the brackets are straight so you just go straight through. on the front you have to offset the cuts the outer cut must be longer than the inner cut. a drill press makes this job a lot easier because you don't need to use the inner drill for a pilot. I just did this for the rear 14 bolt. I have pics somewhere if you want. highdesertranger
highdesertrange
kalifornia
mike
k30
here's some pics.
I also made these for the upper mounts for anybody that has dealt with the factory pos upper mounts on 1 tons.
highdesertranger
87silveradok20
Ohio
Levi
Silverado k20
here's some pics.
highdesertranger
I bought rear ones already. But I may still make the fronts since I can't find any.
What's wrong with the 1-ton upper mounts? I haven't had any issues with them before.
highdesertrange
kalifornia
mike
k30
the stock upper mount are non serviceable on the 1tons. the stud is welded to the bracket and even if you can get the stud off there is no way to get nut behind because there is no access and the bracket is riveted to the frame. one of mine was broke and the other cracking. so I made new brackets that are serviceable now they take the same stud as a 1/2,3/4 ton. I had a new set but I wanted to make them serviceable. here's a pic of mine and the crack.
highdesertranger
Hmm, I haven't run across that before. Were your shocks possibly too long or too short at some point?
highdesertrange
kalifornia
mike
k30
well I have seen this on more than my truck. in fact most of the 4x4s I have run across are at least cracked I think it's just metal fatigue. doesn't seem common in the 2wds. highdesertranger
TheRigLivesOn
