Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Specs?
Size?
Grade?
Torque?
It’s a shock bolt. whatever diameter and length required.
It’s in shear or tension depending on which bolts you’re referring to so doesn’t need to be a hardened bolt but for the extra 20cents each you can use a grade 5 or 8.
Torque. Good n snug
