Shaking While Stopping??
1low4x4
Nick
Had the rotors and drums turned yet?
gearheadmike
West Chazy Ny
Sierra K2500
Lol I'm thinking it might be drums just saving up some $$ there not cheap!
1low4x4
Nick
Have them turned and they may not be bad.....
gearheadmike
West Chazy Ny
Sierra K2500
I brought them and the guy said they have been turned befor and there not enough left and said if it has been turned to much could cause only the middle of the pad to touch.
Did you try the e-brake test yet - to isolate the problem as front or rear?
gearheadmike
West Chazy Ny
Sierra K2500
My cables are pretty crappy I think I'm going to unhook the line at the t on the rear end and put a plug in it so the rear brakes won't work at all and test it on my road (not busy road)
Then see what that does.
gearheadmike
West Chazy Ny
Sierra K2500
Well after all new rear brake parts - shoes drums adjuster kit spring kit parking brake cables it Still does it!! Grrr. I don't know what it could be and it only does it when stopping from over 35 mph
350runner
tx
Ceasar
If you feel it in the pedal check the front if you feel it in the seat check the back.
gearheadmike
West Chazy Ny
Sierra K2500
it feels like the cab-seat is shaking but I just replaced all rear brake parts drums-shoes-ect.
farmerchris
southeast kansas
chris
if you have a isolated road,take the truck down the road in reverse at about thirty miles a hour and apply the brakes,do this several times and see if it make the problem worse or better.sometimes helps by adjusting the tension on the rear brakes.might isolate the problem too.
350runner
tx
Ceasar
Can you feel it in the pedal?
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
Have you went and had the front rotors turned or replaced yet? I couldn't find if you said you have or not. If not I bet the problem is there. I've seen a lot of trucks get warped rotors from just daily driving.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I had same issue.. had replaced everything was still doing it.. then had the rotors turned on the hubs trued it up stops nice and smooth now
Repeat:
All stationary driveline components (axle tubes, transmission housing, transfer case, etc.) have been inspected and found to be securely mounted to the frame - correct?
Rotating elements of the driveline (driveshafts, axle shafts, gear sets, etc.) are in good shape, properly balanced and correctly indexed. U-joints are tight and any splined joints can move freely in the axial direction. IMPORTANT - Any bearings that support the rotating elements of the driveline have no excessive play.
tannerscarber
