Handy Andy
- Jan 19, 2016
- Stanley ND
- andy
- sierra 1500
Ok Gents, I'm getting ready to do my serpentine conversion on my 86 gmc k1500. I've picked up a donor 350 out of a 99 k1500. It was free so hopefully it will work. I can already tell that the idler pully needs to be replaced because it's loud as heck when I spin it by hand. I've got most of this stuff all figured out I think.
I've ordered an adapter to go from the si to cs alternator, I ordered it with a resistor because my truck has a voltage gauge instead of a dummy light. Rock auto has it for pretty cheap.
http://www.rockauto.com/en/moreinfo.php?pk=663890&jsn=284
The one thing on this that has me somewhat stumped is how to wire up the a/c. I understand that the clutch wiring should be a straight forward simple plug swap. What's getting me is the High pressure switch off the back of the pump. I should be able to just wire this up in series with the low pressure switch in the existing a/c system on the truck right?
The Red Rocket is undergoing a few decent changes this next couple weeks. I've recently swapped in a mini high torque starter rated for up to an 18.0:1 compression ratio so I will hopefully no longer have starting issues due to higher compression of the new motor and heat soak from running headers. Next is the serpentine swap which I will hopefully get finished up on Tuesday. After that, but probably at the same time as the serp swap I am going to swap out the old clutch fan for a dual fan ford Windstar setup I found at one of the local junkyards.
Anyone ever done a serp swap like this using the same 99 k1500 serp setup? Any pointers or tips?
