Serpentine Conversion question
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I have everything from an 85 k10 305 and an 87 R20 350. ive only tried the 87 pump. im not free till thursday to look at it to see if the 85 is any smaller or different.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Ok both pumps I have look identical. The85 305 and the 87 350. They have the same numbers cast on the back. So either GM truck smog pumps were all the same or the 87s was replaced with an older one. I'm just gonna remove it for now to get the truck running. I was also having a problem finding the correct belt length for the system w/pump.
Boone83K10
Boone, NC
Benjamin
I'll pull it if you guys have suggestion on how to pass a visual emissions test. And will it do anything to the ecm for the tbi by not having it there? I know it has a wire to the obd1 plug
Just delete it, if they give you grief put the old back on for one day, pass inspection and swap it back again.
Thank god Watauga county in North Carolina is safety inspection only.... None of that emissions crap...
8T6K5
AZ
L98 350 TPI
usar17
PA
K20 Silverado
TBI350/700r4/NP208
With AC. Just tried a 970k6 belt. Little too loose. Its looking like deleting it and paying off the inspection police
usar17
PA
K20 Silverado
TBI350/700r4/NP208
The cast markings on the back are 7832904. There is also a "23" stamped next to a "DF" inside a football looking oval. above the output port is "METRIC" then "0519"
CadenJoel
