Seeking softer ride
Swims350
Logan WV
none
I could see that happening, I wouldn't want a corner carver anyways but being able to do a cheap lift is awesome, swap in some 52's up front, then out back do some shackle flip or blocks and bam a cheap 4 inch lift. IF you can find or got a stock set of 52's.
In essence yes it is, years ago I had a 89 K5 lifted 4in on 33's that was stolen after having it for a week. Ive also had 2 OBS being a 94 Z71 on 35's and a 94 2dr Hoe on 33's... Its just my only gripe about the truck and is any means for improvement, I have the skill to complete somthing drastic on the suspension to make the improvements its just the lack of money and knowing whats a common thing on these trucks to remidy being bouncy lol.
These other older 4x4 trucks you had in the past are all Independant Front Suspension (IFS) A big differance than the Straight Axle Suspension (SAS).
Yes, by all mean, if you are running a 700r4 with those tall of tires and 3.08's, you need to get that axle swap done sooner than later. You are killing your 700r4 wth that strain. With that tire, I'd prefer 4.10's for certain. You're 700r4 will love you for it.
hirschdalechevy
norcal
rich
k-30
The only lift kit I ever had was a skyjacker softride 6" lift on my '78 Burb and it rode real nice.
I run skyjacker softride on all my old trucks with rancho 9000's and I think the ride is great. I have had , superlift , trailmaster , pro comp , rancho's , and I pitched them all in the trash for skyjacker's. I have some buddies that have deaver leafs , custom made , thats what I will run on my next project , but they are the bank , but they are nice . They will make them for any ride you want and you can keep it soft in the back and run air bags or a overload top spring that touches when the back comes down 3 or 4 inches for carrying loads.
my4by2
Pearcy, AR
Michael
K30 Crew Cab
6.0L LY6
Agreed - I am running a Skyjacker lift on my truck & pretty much always use them! Also running their Nitro shocks. My truck is a 1-ton so just deleting those HUGE leaf packs for the Skyjacker ones is gonna make a HUGE difference!!!!
J@meson
Elizabeth City NC
Jameson
Well I stand very corrected it is not a Tuff country lift. I double checked and it is a Skyjacker kit... Dam my ignorance lol
master_tech
Nettleton, MS
Rusty
K-10
SBC 327
My 86 w/ rancho 4' kit w/ softride springs and rancho 5000 shocks rides like a Cadillac.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
You may want to check the shackle end of your front springs. If you have stock shackles you could be having contact between the frame and the eye of the spring severely limiting movement. I doubt it but it wouldn't hurt to check. I think there's a difference in spring length between 73-78 and 79-87. If you have the wrong ones (too long or too short) that could hurt the ride quality too. I'm not 100% sure on the year break but it's worth checking into. Also you could try removing the hardware and bushings and lube them with lithium grease. If they're dry they could be seized up preventing free movement. I have a set of ORD greasable eyebolts all the way around on mine, helps keep things moving freely. You may also want to check the cut/taper on your springs (width and thickness taper). If they are really square cut with no 2-way taper they will ride rougher. If they are indeed Skyjacker Softrides they should have the 2-way taper. I would check the shocks too. If they've been over-extended (like mine) the first 2-3" of travel is thrashed and has no dampening at all. Take the bottom loose and try to push up and down on the shock. If it isn't really hard to move for the first couple inches, they need replaced.
Square bodies all use the same length front springs, well, lift springs anyway. It wouldn't surprise me if the factory springs differed in length slightly. Sometime in the 80's though, the shackles increased in length a little.
angusdevil
Tempe
Craig
c30
454/sm465/205
Any of you guys ever think about upgrading to something more than "out of the box" suspensions and whitebody shocks?
crazy4offroad
K-10
350/SM465/NP205
You talking 4-link/coils and remote reservoir shocks?? Thought about it and it just equals more expense to me. This project has enough expense as it is! :crazy:
angusdevil
Tempe
Craig
c30
454/sm465/205
Nope, don't have to go through and 4 link (albeit very cool) but just having them make some progressive rate leafs. Ya, it'd be more expensive but the payoff would be WELL worth it. As for shocks, some Bilstein or Fox 2.0's would be great and only cost about 1k. The trucks already ride like wagon's, for a couple grand, they'd ride like caddy's and take quite a bit more abuse offroad if ya wanted.
Now for a street only truck, you're absolutely right, not worth it at all.... but whats the fun of having a truck pound pavement all the time :D
crazy4offroad
K-10
350/SM465/NP205
Mine's no street princess and I abuse the **** out of it with just out-of-the-box lift parts and whitebody shocks.
only cost about 1k
LOL no way I would put that much in shocks on my beater. It rides actually pretty good the way it is.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
J@meson, post a pic of your front shackle, and its angle in reation to the frame.
angusdevil
Tempe
Craig
c30
454/sm465/205
Haha, we have our own style out west. It's not about if you can take on the obsticle but more of how fast you can do it.
82jimmy
