lusktommy
- Jul 17, 2012
- Tuscola, TX
- Tommy
- C10
- 5.7L (350ci)
i have alot of random stuff that i need to get rid of..they collecting dirt and rust and need to be used...
2 305 heads they are not the same they have different size chambers they are boxed up and i dont remember cast numbers..but i will tell you they are fresh built...ran maybe 50 mile on new engine until it a rod bearing went out due to lack oil pressure flow..cause by a bad relief valve...and there are the heads that were on the 305 that was in the truck originally when i got the truck dont know why someone would put mix matched heads on but anyway i was unaware of this when i put them on my new 350....if you are interested i will be more than happy to get pics of them and casting number for you....but one is a 76cc and the other i think a 53cc with 1.84/1.50 305 valves
i have a summit racing cam Part # SUM-1785 very mild would be great for any stock engine was in the engine with the heads..dont worry upper end lube was good..this came is like brand new..also have a set lifters that go with it that have been submerge in Castrol HD30 since they came out with the cam.
have a Crane Energizer Cam kit with new matched lifter 266 H10 for the specs on it but you can google it..it has never been run i got in a deal when i bought my new head that are on my truck now...i already had a bigger better cam when i got this one..it will need to have the cam bearing journals clear by a machine shop..very very light surface rust..it was that way when i got it...i put grease on them when i put it in storage. the lifers are new like brand new no rust and have also had a layer of grease on them when put back in original box for storage.
i have a 400 crank that was given to me..brand new never run..with very very light surface rust that is in the same shape as the cam above.
i have a Cloyes double chain timing set never been used or open..still in original package..vacuum sealed
original air cleaner assembly for 83-86 305 350.... rochester q-jet is what it came off of.
all new vent A/C heater ducting for 80-86 Chevy GMC
if anyone is interested in any of this and wants picture text me at 325-338-4451 we can talk prices and i will give more detail if want more..you can try to call me but i have poor reception in my house..also i only accept paypay for payment
