Edelbrock
Senior Member
- Mar 28, 2025
- Earth
- Grumba
- K5 Blazer
Keep it under 3.5K RPM and it never ticks.
Rev it up to 5K RPM intermittently and it never ticks.
Hold the RPM above 3.5K for 5-10 minute and it taps badly.
Once it starts tapping badly, if you let it idle or drive with low RPM for 5-10 minutes, the tap slowly goes away and then disappears.
TAP TAP TAP. Not an exhaust leak, this is a hard lifter tap.
Lifter being starved? Lifter hanging up? Push rod magically shrinking in length and then lengthening itself after you stop rapidly spanking it?
