Short block is done!!
Finished it up this morning, last thing being done is the painting of the oil pan and mounting it.
I did make one small mistake...overtorqued one of the rear main housing bolts. Before putting it on, I used a small thin coat of silicone on the gasket, so I should still be ok.
Here you can see my oil temp sender mod. 5/8s hole is perfect, and a liberal amount of JB Weld seals it up just fine.
There was something weird about this block. It had NO dipstick hole....just the boss. Did my best to drill it out, so here's hoping the tube mounts in just fine.
And...those valve covers
Next step are the heads and intake....stay tuned.
