Sandrail or dune buggy out of my truck
Luis of EP
El Paso
Luis
r-20
Has anyone done this?
Is it easier to just use the frame off my truck and make a roll cage over it?
Or start from scratch?
8T6K5
AZ
L98 350 TPI
Im no engineer but if you have the means to make a roll bar from scratch, you have the means to make a frame?
Luis of EP
El Paso
Luis
r-20
Yes I will have the means to roll pipe, I can weld almost anything and i have a neat plasma cutter that's looking to cut some things too
Green79Scottsdale
G.R. - MI
Bob
Start from scratch. It will be more rigid that way.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
The best is from scratch or you can box the frame and build what you want from there and save time on the geometry for suspension steering and axle location but it sounds like all that is not an issue for u but to save time just make your frame suit your needs u have
thom9719
