- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
While I was disassembling my truck exhaust to remove the engine, I had all 3 studs twist off on the driver's side. I have been soaking them with Knock'r Loose for the last 4 days and tapping with a hammer. Last night I decided it was time to tackle swapping the news studs in. I didn't use heat. On the broken studs I decided to use my Porter Cable impact screwdriver. I cut a slot in the studs wide enough to get the flat bit in, and deep enough to get a good bite. The first one backed right out. Second one I should have tried tightening first and then backing it out. Busted both bits I had. Third one I used vice grips and tightened it first then started walking it back and forth and adding Knock'r Loose as I progressed.
The passenger side all came out with a small pipe wrench with the tighten first and then loosen method.
I need to get an easy out for the other because stupid me decided to cut it off flush. I should have got more bits and used the impact because it worked so well. Just the cheap-made China bits couldn't hold up. Lesson learned.
