Rust repair questions
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
I feel the pain you speak of my friend!!!!! I have a couple supports that are just....gone......
I hand formed all this flat steel in multiple are's on the floor pans. In the top image you can see one of the supports rotted away....that will be next.
jlmohr76
roland, iowa
jesse
jlmohr76
roland, iowa
jesse
Passenger side floor isn’t as bad as I thought. The driver side tho‍♂️. Someone has been in here before. There’s a hole cut out above the body mount bolt.
jlmohr76
roland, iowa
jesse
It appears as tho water has been leaking down on the driver’s side. I’ll know more after I cut the cowl off
Houston
I'd bet a Benjamin it's leaking between the firewall and cowl seam due to failed seam sealer.
jlmohr76
roland, iowa
jesse
jlmohr76
roland, iowa
jesse
Just trying to fit the pieces together.
Do you have a rotted sill under the floor there? That’s a piece it may pay to get in a new panel since it’s a structural piece, but you could fab something if you’re skilled I suppose. Kinda hard to get the load bearing aspect and he door frame to be rigid without that piece it seems sadly.
jlmohr76
roland, iowa
jesse
I’m going to fab up a piece to replace that hole in the seat riser area. Trial fitting everything now
I mean the piece that runs forward to back under the floor and also the one that cuts across from the center if I’m remembering correctly. They have a rectangular box look to them about 4 inches wide about 4-5 tall I think
jlmohr76
roland, iowa
jesse
The cab braces and support like these?
jlmohr76
roland, iowa
jesse
I’ve cut those out and have them mocked up into place. As you can see they were shot! Lol
jlyon1006
