Runs out of fuel…
Okay now that you're paying attention instead of arguing. Still 1st thing is check pressure and volume. 2nd the qjet you have is going to have to go away. All qjets are not the same, not even close, and you will not be able to make it work right on your 305. I could but it is a process. You need a qjet for (your) 305 or as close as possible by year and options. Or go with a more universal carb like a Holley. 3rd when we get the fuel and carb worked out you're going to have to learn about timing and yours is going to be rough .Do you still have your ESC distributor laying around? If so it will make your life much easier.
Now as for your timing 305s are a 3.73 bore, and ESC 305s had compression of I believe it is 9.5-1 Ideally you are going to want about 36 degrees total and then we are going to add vacuum on top. With that compression, that bore, and no EGR we are going to have a tough time getting the optimal curve,and total without getting pre ignition. But let's climb 1 mountain at a time. Check fuel pump pressure and volume. Then we'll move to the carb. And seriously you will never get the right jets, hangers, metering rods, secondary door tensions figured out. So just count on replacing the carb.These are not simple carbs, that's why most can't make them work.After all that I'll walk you through ignition. NBD.
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
I do not have the old distributor.
K. NBD, would have been nice to have the springs weights eccentrics and vacuum can that went with your engine, but we will work with what we've got.
It's super confusing to read this whole thread through... but based on Rusty and Ricks comments, I'm assuming there were a whole lot of edited comments:happy175:
Like they have already told you.. first thing is to troubleshoot the engine. If it was me, and a completely unknown history engine, I'd start with the basics.
  1. Run a compression test
  2. Depending on whether compression number are within 5-10% of each other or not, run a leakdown test if not.
  3. What is your idle vacuum reading?
  4. Check fuel pressure and volume
  5. Stop spraying your air cleaner with starter fluid
oh, and
6. Check mechanic TDC mark for accuracy.
He's installed numerous fuel pumps and rebuilt a mystery qjet. He's having fuel issues and didn't want to check pressure and volume even though that's what I told him to do several times. I suspect his fuel pump lobe is worn, and he needs to get the right qjet or something less troublesome for him than trying to make a BBC qjet work on a 305. Now that he's willing to accept the fact, you have to test things, you can't just assume they are good,because when tests pass or fail we know what direction to go. Now I think this will be easy from here on in.
Yep... spend weeks chasing your tail or just get everything you need to troubleshoot the issue down to the ACTUAL source in a few hours of work. Sometimes we trick ourselves into thinking it will be faster to just throw a part at it, but that almost never works out well.
I just did some modification to my factory quadrajet last night in preparation for installing it on the NEW motor this week. Converted hot air choke to electric and new idle mixture needles with a 5mm hex head instead of the terrible double D head the originals had. Should make it much easier to dial in when its running right again. This afternoon will be going out to a guys house form the local squarebody group to dial in his idle mixture, idle RPM, and timing so that it drives decent again. He swapped in a new motor with an edelbrock and doesn't know how to do the fine tuning, so hopefully I can get it dialed in for him without too much trouble.
Octane
Atlanta
Eddie
May be it'll turn out to be a disconnected/ missing vacuum line.But I would troubleshoot that fuel pump...the 38th time is the charm? Lol. But all I see are questions and recommendations but not much action by the poster.Ricko1966 has tried real hard tho.
BJedi76
Soldotna, Alaska
B.J.
305”
I can only work on it on the weekends.
working on vehicles is a lease violation where I live.
The manager lives 80 miles away and doesn’t come around on the weekends, so I chance it when the week is over.
Fuel pressure and volume test is next.
I just have to wait till Saturday.
Rusty Nail
Rusty
350sbc
A fuel pump volume test consists of attaching a hose long enough to collect gas in a container, cranking the truck over (enough to start it) and determining if you think that's enough gas or not. Pretty straightforward!
Btw, you ordered one of them .02 longer Moroso pushrods, right?
I bet that's the fix.
BJedi76
Soldotna, Alaska
B.J.
305”
I’m not ordering anything until I complete all the tests, “Ricko” recommends.
I'm not really seeing how a longer fuel pump pushrod would help if the cam fuel pump lobe has been wiped out. Generally when the lobe is wiped it only wipes the tall side, which makes it almost round. If you have no eccentricity to the lobe, it won't pump even if the pushrod is making contact.
Volume cranking with starter, disconnect power to distributor. Crank 30 seconds you should have approximately 3/4 cup of fuel. For your pressure test I forgot you have 3 line pump.1 of those is a bypass return. So your gauge is going to jump up but not hold so watch the gauge while you are cranking
JoeyC75
