Rubbish Problems (help)
Oaasport
Justin
Suburban V10
OK so I got a used set of good looking rims on my 1987 Suburban. Bolted them up with brand new 285-75-16 tires. Clear fenders fine (did a notch trick). Drove fine all the way up until some dude parked right up against me and I had to turn it sharp. Long story short, i have my rim rubbing my ball joint! I need to purchase new rims and have money to do so. I wont put spacers on because i have short studs and not enough time in the day to even change wheels out lol. with the 285-75-16 tire what size wheel will be wide enough, and what offset and back spacing will clear? I found some pro comp 16x10 for decent price but have no idea what off-set or back space i need.Any help i can get i will appreciate. i am not a wheel/tire guy
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I had that same tire size on a stock 8 lug steel wheel, 6.5” width I believe. I now have that size tire on an 8” rim.
Factory backspacing is 4.5-4.75” iirc.
Mine are 16x8 with 4.5” BS. On that small of a tire 16x8 is perfect.
I think @Craig 85 has 16x10s, but with 35s and a 4ish” lift.
Edit: I wasn’t looking through prism of a non k30 truck. Nevertheless, Craig has had these trucks in all different configurations and will likely know what’ll fit.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
16x8 also works fine with a 35" tire, just saying.
jlyon1006
