Roof rack install pictures. Half DIY basket and Factory OEM roof rails
Giant Rock
Joshua Tree, CA
Cole
Suburban v1500
5.7 V8
I ask a bunch of dumb questions around these parts and really appreciate the help. I don't have much value to offer but thought I could at least post about this roof rack I installed.
I wanted to install the factory roof rails (I bought them on Ebay for like $250) plus add a basket up front that could hold a full size 33inch spare tire plus some fuel and things like a shovel. Most roof baskets were not wide enough but I finally found one that was the perfect width. In order for it fit along with the Factory Roof rails I needed to install the rails farther back than I believe they come normally. It took me awhile to figure out how to mount it but eventually found these awesome Gutter Mounts by Smittybilt. Also your standard roof rack bars from companies like Thule and Yakima are insanely expensive. I opted to by a 10ft long piece of Superstrut from Home Depot for like $20 bucks which I then cut to fit and sprayed with bed liner, works perfectly and is strong as heck.
Now that it's all installed I couldn't be happier. Thanks so everyone here who helped along the way.
View media item 9196View media item 9195View media item 9192View media item 9190View media item 9191View media item 9185View media item 9184View media item 9183View media item 9186View media item 9187View media item 9188View media item 9194View media item 9193
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Fine work! Just remember when loading up the front basket that the gutter rails are held on by screws and not welded to the body. Should be fine for the things you posted though.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Looks really good! Now you just need the ladder that goes on the back door.
NCBurb
WNC
Suburban
6.2L
sweet! Where did you get that ladder? And also is all the weight of that on those little trim pieces over the doors? Will those hold?
TubeTruck
East TN
Denis
Suburban K10
LQ9
That's a pic I found online. I can't find those ladders anywhere. I know Smittybuilt used to make them but they are pretty much Jeepers now.
rpcraft
Robert
LS 6.0 364 CID
I'm somewhat curious what the setup is on the rear portion of that carrier? I'm not as familiar with the Burbs as I am a K5 but looking to maybe setup one in the future similarly. Thanks!
NCBurb
WNC
Suburban
6.2L
Rats. I used to see those all the time on the back of those conversion vans that were all over the place in the 70s and 80s...I wonder if you could cut one of those down, if you could even find one...
MartinK5
