RockAuto- 4x4 front drive shaft, '81 K20 -Rock Auto
JD Miller
Goober Idaho
JD
K20 silverado
It is high quality, not a cheesy china POS.
Guy I know that has a drive shaft shop in Ca does alot of race car/boat and polished aluminum show car drive shafts and he wanted $400+ just to replace the slip yoke and spline and one u-joint on new slip yoke and balance. Rebuilding the double cardan would be more $$
So this Dorman shaft was a good deal
....PS Oops , spoke to soon, see below :mad::insane::mexsmoke:o_O
JD Miller
Goober Idaho
JD
K20 silverado
Damn this Dorman is 2 1/2" diameter tube. My original shaft is 2" and Rock Auto Dorman description says its a 2" also. Part number on box is correct but its a 2 1/2 " shaft
Anybody running a 2 1/2" shaft on a turbo 400 auto square body
Im going to go take other measurement, bolt pattern, other diameters
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Wow, looks like Dorman is stepping it up a bit.
JD Miller
Goober Idaho
JD
K20 silverado
Nope , frickin Cardon CV is 4" diameter, My original is 3 1/2" diameter. The Dorman will not clear the cross member for the trans mount. Too Big :insane:
Original shaft tube is 2" dia , Dorman is 2 1/2" dia
PS
Dormans specs say 2" diameter. I got 2 1/2" and the cardan CV is larger too
Maybe its package wrong... My box dorman sticker 938-192 part number is correct on the box
legopnuematic
Licensed Junk Dealer
MO
Spencer
The wallet with wings strikes again!
legopnuematic
MO
Spencer
Dorman definitely is a mixed bag though, I have generally had decent luck with their products, I know from others they definitely have some clinkers.
Hopefully rock auto will work with you on the return. I had ordered a set of u joint u bolts, got sent a set of outer axle bearings and seals for a 10 bolt car rear. Did the online return/problem prompt, answered the questions. Next day I get an email the replacement shipped. No complaints with the process.
JD Miller
Goober Idaho
JD
K20 silverado
It isnt Rock Auto's Fault..... It s a Dorman Fudge-up
JD Miller
Goober Idaho
JD
K20 silverado
It may not fit the particular application due to the larger size, but it does indeed look to be a quality unit.
True , quality, But its all over size and wont fit
JD Miller
Goober Idaho
JD
K20 silverado
Not pic of mine , same though. Compare 2" with 3 1/2" Cardan and 2 1/2" with larger 4" Cardan. The double Cardan u-joints are larger also
JD Miller
Goober Idaho
JD
K20 silverado
I called the number on the Tech support card that came with the Dorman Drive shaft.
PowerTrain Industries makes the drive shaft for Rock auto.
PowerTrain tech guy says they dont catalog/make a front drive shaft for 87 and older chevy 4x4 . The 938-192 driveshaft is for 1988 and newer chevy. So Dorman is Cataloging the '88 and newer drive shaft for 87 and older chevys
I replaced my entire front driveshaft years ago, from a place called Driveshaft Specialists in San Antonio. I lived there, so it was local, and it worked great.
Last year I started getting loud clicking noises and determined it was the universal joints in the CV joint of the front driveshaft. Ordered all new universal joints, along with the CV centering yoke (which had fallen apart), and they were easy to replace. Also lubed the slip joint and made sure it moved easily. Based on that relatively simple job I think I would just “rebuild” it myself.
JD Miller
Goober Idaho
JD
K20 silverado
My slip yoke is worn bad
Spline shaft of the slip yoke need to be cut off on a lathe and weld new spline onto the shaft tube and then balance. Job for a drive shaft shop. Sure the rest i can do my self
I found a drive shaft shop in Ogden Utah that will build me a complete all new, proper 2" dia drive shaft with a stronger full spline slip yoke, and ship it to me in Idaho at a good price
SquareRoot
Look at the bright side... :hump:
JUKA
