RETRO-Mod: Jeep intermediate steering shaft
The88
Mhmm
South Louisiana
ThatGuy
Hell yeah. Thanks for the insight and added information about the swap. If you have a picture after install with total length that would be good too.
beest
indiana
matt
No problem, i got the xj shaft at my local pic a part, best 13$ update on my truck.
Sent from my SM-G920P using Tapatalk
The88
Mhmm
South Louisiana
ThatGuy
OK I know I have peppered this thread with a few back to back posts but if anyone is looking for a new lower shaft check out morris 4x4. Part number is a Crown 4713943. Make an account with them and use code 10thanks at checkout and you can get it shipped to your door step for $94.99.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Not trying to be the forum jackass here, but I've got two of these shafts used. $50.00 money order or $51.20 cash using COD through the post office.
The88
Mhmm
South Louisiana
ThatGuy
jimmy you head toward lafayette?
beest
indiana
matt
I got mine from pic a part in indy for like 13$.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I haven't even been to Lafayette, bud. :) I'd be willing to meet in Baton Rouge or something like that. That'd be too far for you, though, huh? You're in the W-NW Louisiana area. Is New Orleans ever on your map? I've got them with me here.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Actually... There's this young lady who lives a few doors down from me in the dorm who goes home to Ruston once in a while. We're only acquaintances, but I might could talk her into it. Is that close to you? If that would work, it'd only be $50 since I'm not dealing with the USPS.
The88
Mhmm
South Louisiana
ThatGuy
I am in the South. about 2hrs30 from New Orleans right off of Hwy90.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I must have had you confused with someone else then... Do you know where Gibson, LA is on U.S. 90? I could meet you there sometime next week. Tuesday would likely be the best day.
The88
Mhmm
South Louisiana
ThatGuy
right now i am offshore and don't know when i will be home
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I gotcha. Let me know when you get back, and we'll figure it out. You've got dibs on one unless you say otherwise.
Camar068
10 yrs Air Force
Got another today. I put a self sinching loop around a bradford pear limb then put it on the int shaft. Same thing on the other end except to ball hitch.
Popped right out with no throttle. Be a good idea to secure the end by the truck to the tree so u dont hit the truck. Luckily mine went under the truck.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Be careful with that shaft. I had one that was just like that and got it installed in the Jimmy. It was good on the ends but had play in the middle. I ended up chunking it and using my last one that I had to do the good old heat, compress, heat, and expand. It was perfectly safe, but I want that 100% tightness.
1low4x4
Nick
I think Im going to try this. With a 4" lift and 35's, brand new draglinks, brand new connecting rod ends, balljoints, sway bar extensions, greasable leaf spring poly bushings, a new rag joint, and a new steering box, It STILL has play in the wheel like a worn out Mexican dump truck. Its unbelievable after all those upgrades. 4-6" of play in the steering wheel before the wheels respond.
tannerscarber
