Replace Steel Dash
mrghostwalker
Connecticut
K10/20
Has anyone pulled out a steel dash from a square Chevy? Mine is mangled up and needs replacing.
eskimomann209
Modesto
Marcus
Yep. unbolt four bolts on inner side two in passanger side two on driver.
Above the kick panel area.
remove the braces. Some trucks have two some have one.
pull windshield.
drill out spot welds along windshield gasket seam. Spot weld drills exist.
Split the seam. Lift up and out.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I think someone had one for sale here not long ago.
Dleslie212
Phoenix
Dustin
5.7L 350
pull windshield.
Old thread I know. Has anyone done this recently? I'm curious how difficult it would be to replace mine
Ken B
indiana
ken
I did it. You should use a spot weld cutter to go across the top where the dash meets the windshield/firewall
Dleslie212
Phoenix
Dustin
5.7L 350
How long would you say that took? And how hard to get lined back up properly?
Ken B
indiana
ken
it is a bit time consuming because you dont want to cut thru all the metal and drill big holes that you have to then go back and fill in .
Bennyt
Surprise
Ben
This is a pretty straightforward job that looks way more difficult than it is. Buy a couple spotweld bits and go for it. Takes more time to strip all the components from the dash like the HVAC, Radio, glove box than it does to do the job. It has a couple bolts that help you locate and hold and than its just tack welds and minimal grinds.
And you are in Phoenix, the C10 capital of the world. Literally a C10 in every neighborhood.
CheemsK1500
K1500
Just curious, what kind of damage does your dash have? Is it rusted, wrecked, or did someone botch a radio install horribly?
CheemsK1500
K1500
LMC actually sells complete new ones now in three styles. I’m not really sure what difference between the styles is, other than the location of the winshield wiper switch and slight changes to the shape of the bezel and pad.
Dleslie212
Phoenix
Dustin
5.7L 350
I actually saw the three dashes in the LMC magazine yesterday, which is what got me asking this question
My dash is pretty mangled, especially around the steering wheel area. Most of the smaller, thinner braces are broken, bent twisted and dented, to the point where the wiper switch doesn't even sit straight and flush anymore, it's installed at an angle
kkgp81
Kelley
NVM, stumbled across the actual LMC page, 3 different year sets.
As a twist to this, on a 81+ how do you handle the VIN plate?
SquareRoot
pull windshield.
You made a sh!t ton of hard work sound very elegant.
Auburn, Washington
I’d honestly consider cutting out the bad **** and welding in pieces out of a donor cab if it’s only a couple areas. . You can get any free fcked up cab with a good dash.
Unless you’re really motivated….I hate drilling out 50 spot welds lol.
In the end it might be about the same amount of work though either way…
Burban90
