Replace gauge lights with LEDs?
Tennessee
James
V-10
Anyone done this? If so, does it make the gauges any brighter and how many SMDs did you use?
When I was searching that site for info I specifically saw a info box saying the LED's for dash lights can be dimmed.
Posted from mobile...
Driver4r
Nebraska
Trevor
k10,c20
Slick, wanna post up a picture of them on to give us an idea?
SlickGTP
Houston, TX
Can't find one of the entire cluster, but this gives an idea... The tach doesn't have and LED on it, so you can ignore it.
SlickGTP
Houston, TX
Hmmmm, perhaps I bought some from before they made them dimmable?
Fugger stood out clear as day, not even looking for dash lights, looking for an answer to that turn issue we are discussing, boom, out of nowhere I see this info that the LED bulbs should dim in the dashboard. Of course now that I try and go back and find it I can't....
Tennessee
James
V-10
Yep, I think this is a go for my truck. From the looks of it, the blue LED is brighter than stock bulbs. So clear LEDs should be a little brighter. I just replaced all those darn bulbs, and the dash isn't as bright as I'd like it to be.
Tennessee
James
V-10
Slick....which bulbs did you use? There are a million and one diffrent choices. I'm looking at the ones with the 4 leds around the sides and one in the center. But I don't know what would work best. there are ones with all the light facing out with no light out the sides. So many diffrent options and choices...
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
LEDs do not dim the same as regular bulbs. Special LEDs with circuits may. But I used cheap eBay lights they are a concave type blue one and don't have a ton of output. Perfect. It's annoying as hell to be blinded at night. The pic doesn't do em justice but they look great .
It's more even looking in person.
SlickGTP
Houston, TX
I used the ones with 4 forward facing Leds... I'll see if I can find the link
Christian Nelson
Wisconsin
Christian
K15
I'd like to do all red, since the red doesn't affect your night vision as much.
Some day maybe.
Tennessee
James
V-10
Ordered 10 packs of both of these. Less than $10 a piece off eBay. The ones with the LEDs around the sides I am gonna try in the cluster. The other ones I am gonna use in the side markers, licence plate, 4wd shifter, and the high beam indicator.
Tdabney
