Removing truck beds
davbell22602
Bunker Hill, WV
I Dont
Have
One
it don't matter you can do it, remember my pics of the motor swap between the MC and the 84 c10, same thing, pull the motor, push the truck back, pull motor push car back, sit motor down etc. I had to set the motor in a wheel barrow and then roll it in place, pick it set it, lift it, push vehicle under the motor and drop em in.
It works man, poor boys got poor ways, you know, you gotta do what ya gotta do. I don't have any 'crete to work off of or anything, gotta get by howeer ya can if you can't afford a big slab poured or something.
If you had enough wood, lumber/boards or plywood you can build a deck to roll the picker on, I built one, just wasn't long enough, plus it let the picker legs hit the lower control arms, so it wouldn't go in deep enough.
I could try to see if i have long 2x6's.
Swims350
Logan WV
none
that's what I used, it's just if you got enough to make it long enough to roll it away from the truck or not. Some 5/8 or so plywood works on the ground if it's firm, now if it's muddy or something might break the wood.
davbell22602
Bunker Hill, WV
I Dont
Have
One
18mm is the right socket for removing the bed. Theres 8 bolts to remove. The 2 worst ones are above where leaf spring bracket is. My impact is to big and maybe my air ratchet will do it.
Swims350
Logan WV
none
use an extension on your impact, air ratchet aint gonna cut it.
what year you working on?
davbell22602
Bunker Hill, WV
I Dont
Have
One
88 C1500. No room for extension either. There's 3-4inches of space to remove the bolt where the leaf spring bracket is.
Lets keep in mind, this is for a GMT400 model, not a Squarebody everybody.
Swims350
Logan WV
none
unless it's a long bed and for some reason they are different, YES you can use an extension. I pulled my 88 k1500 bed back in sept, used an extension on them, never a problem, there's a hole in the bottom of the frame for it to go straight up thru and get on the bolt.
davbell22602
Bunker Hill, WV
I Dont
Have
One
There's no hole up front by the leaf spring bracket thats made on frame and its a long bed.
Swims350
Logan WV
none
my short bed had a hole, guess long bed is different. gonna have to be swivel then.
lovoy22
