Removing PS Pump Pulley
Kilian
Wisconsin
K
C2500 on its way to a K2500
Has anyone used the pulling kit from Harbor Freight for removing the pulley from a power steering pump? Thanks.
You can also borrow the pulley removal and installation tools from Autozone or Advanced Auto Parts.
ali_c20
Austria
Alexander
C20, K5
I have cheap pulling kit, can't remember the brand. Works as it should, keep the threads oiled.
MrMarty51
Eastern Montana
Martin
I bought a cheap puller set from NAPA, it works real good.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I've used the loaner from Advance with no issue. Now I live too far from any of the auto parts chain stores so I bought a cheapy one from eBay to do the pump on my W150. I'll let you know how it goes.
Brett77
Glendale AZ
Brett
502 stroker
I bought harbor freight puller and it works as it should. I bought it because I had to remove the pulley three different times to get the new power steering shimmed properly.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Yes the HF puller/installer works fine.
Just make sure you keep the puller bolt threads lubed up (as you should with any puller). I put a little anti-seize on them and all is good.
Kilian
Wisconsin
K
Thanks guys for the feedback.
jlyon1006
