Removing instrument panel - dealing with the oil pressure line
Chris64
San Diego
This is a strange thing that I haven't found any help on the internet at all.
It's a 1974 K-20.
I was trying to remove the instrument panel and I'm not sure what to do with the oil pressure line. Everything I see online only talks about the speedo cable and the power harness, which are both relatively easy to disconnect. There's no way I can clearly disconnect the oil line going to the gauge and the connector in the engine bay is a long way away.
The reason I was trying to get in there was none of my dash lights were working. It turns out the flexi-surface was just oxidized and with a few twists of each light they slowly came back to life. That said, I may need to remove my entire dash to resolve another issue (I can still smell mouse in the AC ducts). That will require a full dash removal I think.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You don't need to pull the cluster to work on the hvac. Everything should come out the bottom of the dash. May have to pull the bezel and dash pad though, I think the defrost vents bolt in.
The easiest way is to unhook the line is in the engine bay and pull it out with the cluster. Cap the end after removing to not make a mess. I've accessed all the light bulbs from under the dash, the high beam indicator is the worst one.
For the gauge lights I've found pulling the plugs, cleaning the contacts and bending them out slightly has worked great. I haven't replaced a circuit sheet yet. Gotta find a sweet spot sometimes.
I’ve always disconnected the oil line in the engine compartment. It’s not real hard to reach, and the two nuts for the compression fitting are usually accessible with a wrench.
I’ve been through just about all of my HVAC, and pulling the cluster is not usually needed.
- remove glove compartment door, then take out visible bolts on the A/C plenum and remove the cover. Clean out the mouse nest inside, and all the bolts, pencils and match books that have fallen inside.
Move heat door dash slider to make sure it has full travel in both directions. Adjust if needed.
Start the truck and then move the dash control to various positions to watch the blend door move back and forth when driven by the vacuum pods.
- directly above the transmission tunnel is another short plenum piece you can remove from the bottom, just to provide better visibility. It should give you visibility of the floor heat door, which just pivots up and down to control floor air flow.
- there is another plenum piece running from the drivers side vent over to the center of the dash. It has a short metal bracket bolted to the dash to keep it in place, and at each end I think it’s just pushed into the center plenum and the dash vent. It always takes a bit of playing to work it out of place, and feels like you might break something, but it does slip out.
As long as you are cleaning, you might also pull the dash pad, which gives you a good view of quite a bit behind the dash. There are four screws up above the glove compartment that hold the right side and there is a vent tube pushed onto the back of the far right dash vent . On the left it’s held by the dash bezel screws, so you just remove the plastic bezel. Then pull the pad directly toward you and it will slide out.
I've always removed the oil line from the back of the cluster. I don't remember it being difficult, but it's been a number of years since I last did that.
RaisedK5
Leland
Blazer
Ya. Manual says just reach up behind and take off the nut.
Chris64
San Diego
This is a good description of where I'm at now. Dash pad, glovebox and bezel removed. left and right plenum's removed.
Now I need to figure out the defrost ducts and anywhere else a mouse might have turned into a bathroom.
They sell deodorizer and spray for cleaning and getting rid of the smell from cat urine, but I don’t know if it’s also effective for mice. If you’ve ever rented or bought a house where cats peed on things, you know why you need special cleaners.
hdchevy
Florida
HD
The smaller in length the better for behind the instrument cluster. I have always disconnected from behind. I'm sure disconnecting from the engine side is double I just tend to kink the copper lines when i mess with them on my 1973.
It's a 1974 K-20.
Chris64
San Diego
I'm running out of plenum for them to have a nest built in and the nice thing about plastic is it can be cleaned. The only area remaining is the blower motor and around the heater core (which looked OK looking down from the resistor).
I've found Simple Green to do a good job at getting rid of mouse smells.
D3V1N
