- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Correct my 305 has to have some timing pulled so it doesn't ping, then power is down, so is mpg from the retarded timing so a double hit on the mpg. One from no EGR the second from the retarded timing.And as my giant benefit from this the truck has less power due to the retarded timing.I just hooked the EGR valve back up.I can live with more power and better MPG even if it does help the planet
The guys with boosted LSs are starting to realize they can fight detonation with EGR. The stuff I linked to is good reading material.
Well, it's better if it is all working right. It is WAY worse when it is not working right.
The best way to combat detonation in boosted applications is with water or methanol injection. It does the same thing for quench and temperatures(but better), and without the hassle of trying to plumb exhaust gasses that might be super hot and/or under high pressure. They've been doing that since I was building boosted stuff back in the 90's.
What they have mainly gone to now on the big power boosted LS stuff is just running fully on E85 or E90. You have a little less energy density in the fuel, but it burns way cooler and is very resistant to detonation.
